Nigel Watts
- London N7
My 1840 semi in North London, sitting on London clay, was originally built with a small two storey extension at the back (sticking out only about six feet). We extended this by a further six feet or so about four years ago. The new extension, unlike the original one had some chunky foundations, as required by building regs.
The whole rear extension (new plus old) is now doing a leaning tower of Pisa act, and has detatched itself from the main house. The crack at the top is now more than an inch wide. To be more precise, it seems to be tipping like a see-saw, with the new bit sinking and the old bit next to the main house rising slightly.
The engineer who we used originally came back to have a look and concluded that the ground must either be too dry (she pointed accusingly at a large Eucalyptus tree some 20 feet away) or too wet - there is a also a damp problem in the new extension, but that is another story - at which juncture she pointed accusingly to the drains.
Digging around the extension shows little penetration of tree roots at the level of the foundations and a detailed survey has just concluded that the drains are basically sound. The house is not on a hill.
My suspicion is that there is no culprit here, just that old house and original part of the extension are quite content where they are, having had 160+ years to settle down, but the new bit is still settling in. The brickwork of the original extension was probably not very well connected to that of the main house, so that is where the crack has formed.
Any ideas/similar experiences? Is it likely to be covered by insurance?
