Any thoughts on this stuff kids?
http://www.stormdry.com
Case studies...
http://www.stormdry.com/case-studies
Cheers!
Case studies...
http://www.stormdry.com/stormdry-test-reportsThis was a lab test performed by Safeguard Europe to breathability of Stormdry, when applied to a standard brick material. This test shows:
A Stormdry treated wall is 90% as breathable as an untreated one. It is also 35% more breathable than the next-best tested alternative treatment, causing less complications
Stormdry can be applied to an already damp wall, which means it is not necessary to wait for weeks for a wet wall to dry out, before starting works.
Performance of Stormdry is consistent across a range of humidity levels.
Cheers!
