chuckey
- wenslydale
It would seem that we are getting excessive rainfall now a days. The old fella down the lane has had his property flooded twice in the last two years - for the first time in 62 years!! The back of my cottage is below ground level but has land drains and seems to be completely dry under "normal" rainfall. However when the deluges happen (>40mm/Hr), the water rushing down the hillside, gets through the base of a dry stone wall, across by garth and floods into the back of the house. So I want to install a 6" high flood barrier on the outside of the wall to divert the water down the hill. My problem is to do it neatly, as the surface of the wall is far from flat or regular. A really upmarket way would be to dress a 18" wide lead sheet along the bottom edge of the wall, with 12" buried and the top 6" tightly dressed to the stone. A really down marker way would be to use "Viskerene" (Sp.?) instead, light blue in colour with its top edge flapping in the breeze. Even rendering would be ugly and difficult, the buried stones would be muddy and it would be difficult to finish the exposed surface nicely, without making the thickness over 3", so it would look awful. I have got a lot of roofing limestone "slates" (about 1/2" thick), which would look nice but for the unevenness of the surface to which they would be fixed. Any ideas?
Frank
Foot Note:-
When we visited after the second flood, I opened the barn door, 30 yards up the lane from the house, facing onto the lane, I noticed a pile of detritus just inside the door. On closer examination, the water had turned the lane into a beck, whose peak level was something like 9" higher then the edge of the road, the water flowed in under the door, "floated " all the wood shavings, which then backed up against the inside of the door as the water receded. :roll:
Frank
Foot Note:-
