I own a Victorian era converted basement flat. The area directly underneath a set of stairs that lead up to the ground floor flat is becoming increasingly damp, mainly on the floor as the ceiling and walls have been tanked previously. I have had two companies assess the situation and both have said I should not be treating the damp, but treating the root cause, which is water ingress from the stairs above. My neighbour appears to have some sort of waterproof sealant (possibly mastic asphalt?) around the edges of their stairs and I was wondering if this could be a suitable solution for me? If so, what sort of companies could help me with this? If not, what do you think I should do instead?
Thank you
Thank you
