I just started work on my dinning room and have just moved out of my comfort zone and could do with a few people confirming that I am doing the right thing.
The end wall of the room dates from 1870 and is stone rubble construction. It suffers from damp and I have identified the following as being possible reasons:
1) The outside ground level is above floor level in places and is boggy. This I plan to deal with ASAP (like tomorrow).
2) The outside of the wall has been repointed in cement.
3) The wall has had multiple layers of paint put onto it which is peeling away from the wall in places. i.e. it lets rain in but not out.
4) The floor inside is solid concrete. (with the odd crack in it)
With all the above, it is not too surprising that I am having problems internally. However, today's job was to investigate the inside wall and especially the alcove to the right of the fireplace.
The inside of the alcove is rendered in a soft grey substance which was very soft and you could easily push a thumbnail into it. This layer was soft, damp, cracked, sounded hollow and I damaged it a bit whilst removing the cupboard doors that originally enclosed the alcove. For this reason I thought it best to remove this layer, to find out what was underneath and so a better surface could be put on later.
The top layer is between 5mm and 25mm thick and is soft enough to push a screwdriver in easily as shown. It appears to be made from porridge as far as I can make out - its not something I have come across before.
The layer beneath it is a black tar like layer which I assume was put on due to previous damp problems. It obviously hasn't worked.
Beneath that is a layer of yellow paint and beneath that is a cement skim of between 5 and 20mm thick. It has lost all structural strength and fell out without hardly any encouragement.
Finally, below the cement is the original wall. It appears to be in a fair condition with my inexpert eye. The mortar around the stone is soft and clay like, I assume this is lime mortar and is soft because it is damp and will harden as it dries or could this really just be clay?
The plan is to remove all the junk that is currently on the wall and bare it back to the stone + mortar. The will then be covered in a lime plaster + lime wash. If I continue to suffer from damp after fixing the outside problems then I will consider dry lining (with ventilation) but that is way into the future.
I've stopped now as I am unsure if my plan is a good one. Am I doing the right thing?
