joatex
- Woodstock, Oxon
Three coats of lime plaster to exterior rubble walls walls 0.56M thick should reduce/seal against wind and rain driven into the wall but would the plaster (harling) also measurably improve the thermal resistance or would there be a need for additonal exterior insulation ? Is fixing insulation to the exterior wall common and successful practice, it would be easier to do so than fix insulation to the interior surfaces.
