Hi,
Have just removed sand cement plastering from inside walls of my rubble stone cottage which I am renovating.
All walls bar one seem very dry and sound.
I have a problem on one gable wall however, where the gable seems to be built on a solid seam of shale type rock. This seam of rock is approximately 8 inches above current finish floor level. and is quite wet indeed.
The ground outside the gable is a little high, and I am in the process of going down as much as I can, but I suspect I will still have a fair amount of water ingress on the inside.
Could anyone propose a solution?
Thanks in advance for your help.
