electrician
House built 1890s separated into two flats on the same floor the party wall between flats is solid brick original plaster long gone just bare brick and I can hear the neighbor fart I’m thinking of putting a 50 mm metal stud frame 20 mm away from original wall infilling the stud frame with soundproofing rockwool 50mm RV 45 then two sheets sound block board edges sealed with Intumescent Acoustic Sealant my thinking is the space between stud and wall will allow the wall to breathe although it will be sealed behind the stud so to speak I’m hoping this will eliminate any problems with damp etc on existing brick wall and not make any on the new wall anyone done anything like this and have they had any problems sealing a wall behind a stud so to speak are there any traditional methods of soundproofing or reduction I can t find any Ive seen woo; sound proofing but little wary it would become damp. Is there anything you can add to lime plasters to make them sound proof ?
