Cocoa
- West Yorkshire
Hello all!
I am looking for some advice on the best way to sound proof a stud wall! Last year, I took down the partition walls on my top floor. Local sources (all completely unverified) think that my little row were probably weavers' cottages, with the ground and first floor for the family, and the second floor an open workroom. The partition walls certainly seemed to have been added at a later date - judging from the newspaper with which they were amply papered, I would say sometime around 1890. Basically, the walls were a row of tongue-and-groove floorboards nailed to a frame, anbd papered over. At a later date, someone felt that faux-wood panelling (using mdf boards and a dark wood trim) would be an improvement on the existing arrangement. Either way, basic sound proofing does not appear to have been aconcern back then!
Anyway, I took it all down to reconfigure the floor to make room for a shower. In its place my builders put up a proper stud wall which we had filled with thermafleece. Not being quite so adept with lime plaster as I am now, I let the builders put plasterboard up, and skim over. It looks nice, but a quiet conversation in one bedroom can be heard in the neighbouring room. Not ideal!
So, here are the options as I see them:
1.) Take down the plasterboard, and replace with reed matt and lime plaster
2.).... or hemp plaster. I have read that it has higher insulation properties than haired lime plaster.
3.).. or even ecocork. What puts me off this option is that it requires an additional coat of consolidation mortar, which needs to be harled. It's not a technique I have any experience at, I don't know if it would work with reed matt, and I am so c,ose to finishing all my plastering I am a reluctant to try and inexpertly apply a new technique (my first attempts at plastering were so time consuming and inexpert, I have redone all my initial efforts!)
4.) Get a flatpack wardrobe from Ikea for that entire wall, and fill it with lots and lots of clothes!
Could anyone advise?
Also, is there some natural insulation inside the stud wall that would be significantly better than thermafleece? I have also considered taking up a few floor boards and shoving some thermafleece underneath the wall, maybe a foot or two on either side. Would that be necessary, as I plan to carpet (carpet + thick acousting underlay)?
