atlasfever
Hello,
Could I get some advice on the following:
Issue: Soundproofing between my flat and the one above.
Notes: I'm in a 1st Floor, Georgian flat, and the freeholder owns the flat above. In contract, he agreed to soundproof the flat above.
Assume: I have a plasterboard ceiling which is affixed to remnant lathe/plaster ceiling. It's presentable enough. However, had copied the cornice to re-instate like for like as the cornice was cracked and falling to bits, so there is a 3/4 foot empty area around the plasterboard.
Question:
I spoke with a sound insulation specialist who said that if I have a lathe/plaster ceiling, then do not put a resilient bar system as it's no better.
The freeholder will lay acoustilay and mineral wool from above, but he cuts corners at every turn, so likely to only do main rooms, but will never do bathrooms nor under kitchen appliances. Not trustworthy. He would likely do an ok job of just re-fixing/tightening the old oak floorboards above.
So, any feedback on what would be a good idea? The plan was to extend the current plasterboard to the wall edge, and then add back the cornice, but I'm not sure if the sound insulation will be good. Especially if that mineral wool will not be added.
Anyway: Any feedback on sound insulation of a ceiling would be great. Thanks.
Question:
