88v8
- Glorious Gloucs
In the torrential horizontal rain a couple weeks ago, a lot of water came down one of the chimneys.
I had put a raincap on the flue even though our stove installer, perhaps under the impression that we live in Arizona, had initially wanted none, but apparently in this extreme storm the overhang was insufficient &/or the opening too large, so this will be revisited when we change the pot this summer.
In the meantime, and leaving aside how the water got into the actual stack and why the register plate wasn't properly sealed, a lot of soot has washed down. This despite the fact that our sweep had spent a good hour inside the flue removing the soot as far as possible before the stove was installed.
There is, or was, a miniature Athabasca tar lake in the hearth (no mammoths) which I have mostly soaked out with newspaper, the formerly clean yellow bricks at the back have shiny tar streaks down them. It's gone from being a rather nice fireplace to a blooming tarry mess.
The tar washes off the granite setts that form the hearth bed, but readily stains the pointing. At present, the damage is largely at the back of the fireplace and not too visible, but I can see that in the process of cleaning up I could easily make matters worse given the ease with which sooty water splashes could sink irremovably into the lime pointing,
So, what's best for cleaning off this mess? Logically, water brought it here, therefore water should remove it, but as so often in life, it ain't that simple.
I foresee the possibility of not removing the tar very effectively, and in the process spreading it around.
Being a car buff, I reach for something like Gunk, but that in itself is rather oily.
Jizer?
Any guidance appreciated.
Ivor
Jizer?
Ivor
