Gervase said:Soot and tar will leach through plaster in time - give it a year and you'll have brown stains if you're using lime plaster.
I know it sounds revolting, but the most effective solution is cow crap - painted onto the stained area before plastering it effectively seals the soot and tar yet allows the surface to breathe.
Now all you have to do is find a cow that will obligingly reverse into your fireplace and then perform...Moo said:Gervase said:the most effective solution is cow crap
