Looking to insulate the walls of the upper half of my 1920s build semi - The ground floor walls are conventional cavity, whilst the upper half is double thickness solid brick and rendered externally with a cement rend & pebble-dash. Insulating the walls internally would be something I could do and avoid the cost of scaffolding. The stairwell is the largest single piece of wall that needs doing and has a step between the lower cavity wall and the upper solid brick. Loosing the step would be nice and would allow for approximately 3" of insulation.
With the recent drop in temperature, condensation has become a serious issue on this wall - My options for insulating are:
With a cement render externally, vapour permeability is going to be minimal, so I'm leaning towards the PU foam sheets. Is there anything else I could/should consider ?
- Celotex/Kingspan PU foam with warm battens & vapour barrier
- 3" stud with fibreglass/rockwool batts and a vapour barrier
- Woodwool boards with a lime plaster finish and no vapour barrier
- Insulating lime plaster (either cork or hemp)
