Would welcome opinions on the following please:
Want to install underfloor heating on solid ground floor of living room and another floor space which is soon to be come the bathroom.
Current setup is living room has red quarry tiles above concrete slab and the intended bathroom has what appears to be concrete slab approx 20cm above some sort of ash and then earth.
Intention is to install underfloor heat so there will be a need to some digging :
Plan is to have some hardcore base then blinding sand then DPM then PIR board then concrete another DPM layer and UFH in screed to finish at floor level.
I understand the PIR is contraindicated for IWI on solid walls, does the same hold true for solid floors?
Thank you in advance
