tobydog
- South Suffolk
As you can see from the photo, I've had to carry out some repairs to the corner of our lounge. This part of the wall was always cold and felt damp. It's had a history of 'damp proofing' by the previous owners but I let the warranty expire when I moved in because I didn't want them making an even bigger mess than they already have. Coincidentally, the outside is where an old TV aerial entered the house. Held in place with badly fitting silicone sealant, it never keep the elements out. I have since re-routed the cable through the loft, and closed off and repaired the hole outside properly. Stripping the inner wall of acrylic based paints has now allowed the wall to dry out somewhat. It is gypsum covered limelite in that corner but there has actually been a significant improvement. I opened up the inside as you can see to inspect the damage. I had to remove a small degree of very rotten and loose framing but have since packed it out successfully with a semi dry NHL3.5 / sand mix. Quite pleased with the result and it's probably now stronger than it was.
To see how far the problem had spread, I took the sole plate in the corner back to solid timber by removing an inch or so of the top of the concrete plinth. As expected, I was able to dig out some very loss and rotten (albeit fairly dry) sole plate down to the original slate course. This has now dried out fully and I plan to pack it out again with a semi dry NHL/sand mix.
Given how rotten the bottom of the sole plate is, I know that the concrete plinth in certainly structural. I would like to pack out the entire length as far as possible, doing it in safe stages, however, is this actually quite foolhardy? Should I just pack out the part you can see and leave the rest well alone? I did a similar thing at the other end for about 2ft and that was successful. Interestingly, the sole plate is in two parts and doesn't meet or line up in the middle!
