Hello
I am new to the forum and wondered if anyone here can help me with a few questions I have on some repair work I need to do.
My house was built in 1785 and is a grade II listed timber framed building. More recent 'modifications' that I have inherited include internal plaster board and fibre glass insulation between the posts and beams, which have also been painted black. Externally the walls are cement rendered.
I have started to strip out the old shower room which is on the gable end of the house on the ground floor - with a plan to replace it with a new shower room. I had anticipated finding a mess of rotten, damp wood work behind the poor condition shower tiles - I was right!
The sole plate in the corner of the room disappeared up my hoover in a cloud of dust, it was only being held together by the black outer crust of paint. The sole plate on the rear of the house is also in poor condition, but I am hoping to keep this and perhaps add some infill blocks of wood. The sole plate on the gable (side) end that is now missing has been in decay for some years as the cavity shows where cement has been forced into the void perhaps when rendering the outside wall. Just to the right of the missing sole plate is an old door way that has been covered up and here the sole plate has been replaced by cement/brick for a short span before the rest of the gable end sole plate continues (this doesn't look too bad. The plinth walls have been covered in cement and modern paint and the floor has a cement screed.
My current plan of action is as follows, although I would welcome suggestions, and I do have some questions. I've added a picture which I thought might be useful.
1. I'll cut out the remaining cement in the sole plate cavity with an angle grinder and try to make this a square'ish cavity then get an appropriate short section of sole plate and put that in the cavity on a bed of lime. I am not sure how to join this to the cement sole plate - which has a square edge. Perhaps I will use the angle grinder to cut a section out of the cement repair to form a half lap joint. But this leads to my first question - how did they originally secure sole plates to the plinth walls? I can't seem to find any evidence of fixings/pegs in the rest of the house?
2. I am going to try and remove as much of the cement render from the plinth walls that I can without damaging them and re-render in lime. At the moment I am drying them out with a fan heater. I also have a nice breathable clay paint that I will use on those parts of the plinth wall that will remain on display - I've used this elsewhere in the house where I've stripped back the modern paint and it allows the small plinth walls to dry out.
3. I plan to re-attach the posts/studs to the sole plate either with some kind of slip tenon and mortice joint or perhaps a sister post. This leads to another question. If I was to guess I would say the sole plate is oak but I can't tell the difference in woods even when they have leaves on them let alone when they are covered in 200 years of dust, grime and black paint. How do I tell what type of wood the posts and sole beam are made from. I would like to try and source the same material. A further question relating to the posts is should I try and splice a new joint on the end or put a new post in slightly offset to the side and then attach this to the original post perhaps with wooden pegs? As you will see from the photographs the posts are pretty rotten and are quite thin and irregular shaped anyway before the rot set in! So if I was to try and splice them then I'd probably have to cut them back probably by a foot or so. Whereas if I jut left them and put a post next to them and attached the two post further up with pegs then I would be removing less of the original material. But will this be strong enough?
4. Then I'll re-fit a shower cubicle and re-tile etc. So most of this work will be hidden anyway - although I plan on trying to leave an air gap with ventilation around the new shower cubicle - whereas previously it was all sealed off. The room also has a single extraction fan which is nearer to the toilet at the other end of the room - so I think I will also add an extraction fan inside the shower cubicle itself - although this would require making a small hole on the outside of the house for the vent. I will also investigate if there is something else I can do with ducting as an alternative and try to re-use the existing extraction point for both the shower and the rest of the room.
Thanks in advance,
David
Thanks in advance,
David
