On the encouragement of the Building Control officer, I am applying for Listed Building consent to install solar panels.
One CO is in favor, the other says "on principal the policy is to refuse, but make the case your case and we'll consider"
The panels would be on the south facing slope of the internal valley of the roof and would not be visible from outside the building as the building is the highest in the area and on a hill. The only place you can see the roof is from on top of the neighbor's roofs on the sam terrace.
Only 2 slates would be effected to allow for plumbing. The supports just slip under the slates.
So if the panels were to be removed in future, the roof would be intact (just replace 2 slates).
The panels will be of the "evacuated tubes kind, as these require less fixing and transmit less stress to the roof structure because they don't have the sail effect of the more subtle flat variety.
Does anyone have any examples of solar panels installed on listed buildings? Or statements from English Heritage, or anything else that might support the solar case?
