Hi everyone, I've been busy checking out cottages with a view to buying and I've noticed something worrying with a few ! On a few of the cottages the land/soil at the rear is built, or has built up over the years, halfway up the wall ! This of course has led to dampness inside the properties. I'm guessing that in some cases it might have been deliberate to guard against the elements ? Hence no windows below the soil level ! In a building a hundred or more years old I'm not sure what damage this will have done to the actual building material.
In such instances if you wanted to improve matters would you dig out, check the condition of the building materials, and then treat the wall with 'something', and place some kind of membrane between the wall and the soil ?
Or would you remove the soil from the wall and a distance from the wall make an area level with the ground area at the front of the building ?
Anyone had a similar experience ?
DERYN
DERYN
