Every (cold) morning our heating wakes us with an array of cracking, creaking and groaning noises. As the pipes feeding our bedroom radiator warm up the floor creaks and pops and makes all kinds of noise which is very irritating. I'd like to sort this out over the summer for the sake of my sanity in the autumn. You can trace the pipes by the warmth in the floor and they seem to run across the joists (inline with the boards) across the length of the boards.
I read a couple of interesting opinions in the Copper vs. plastic thread...
I'm thinking that if I can get the floorboards up and enlarge the holes the copper pipe runs through to cope with the expansion the noise should go.
Can either of these posters - or anyone else expand on my options?
The floor is Georgian boards 15' by 10" across the length of the room. I've very keen to avoid any damage to them. What is my best bet for lifting a couple of boards and putting them back again?
Any help gratefully received!
ANDLime said:I have noticed the former [fixing copper joints as you go] is likely to keep stress in the pipes and is often noticed by the click-click heard when hot water circulates around a heating system. The stiff piping is rubbing against some hard material in the building (usually wood). There is often a considerable twist in the pipe that becomes evident when a straight section is cut.
Generally a system where all the joints are left until last will have less stress and is usually totally quiet.
Aidan said:Aidan - The click-click noises emitted by some heating systems are due to the linear expansion of the copper tube, usually when used with on/off thermostat controls. It has nothing to do with how the pipes are soldered.
