Roger H
- Northumberland
Hi.
I'm looking to replace a section of plastic guttering on an extension to my stone cottage with cast iron to resolve leakage/irestore the building. The rest of the guttering is cast iron but the newer extension is 5-10 degrees or so off perpendicular with the old building. Any suggestion about how the slight offset in the gutter can be accommodated? If I run the gutter dead-straight it will be too far removed from the eaves at one end or the other (or under-sail in the mid section).
If there is no product/fix, I'll try and get two spigots into the hopper head.
Your advice much appreciated.
