paulbandler
- Oxfordshire
I have recently taken delivery of a set of sliding sash windows bought from a specialist supplier after much investigation and angst regarding their cost. Unfortunately during their installation they have become damaged by someone sliding the lower sash up to its limit and the catches on the lower sash colliding with the top of the inner frame and indeed scratching the top rail of upper window. This happened on 2 out of the the 2 sliders installed so far! (3 more to go).
Now while the installer (not the supplier) regrets the damage and indicates that it can probably be made good with some filler it seems to me something of a design fault that there isn't some kind of 'stop' lower catches colliding so readily with the upper frame.
Now I've tried to raise this question with the supplier but as yet they're not being very co-operative, so I thought that I might find some 'sliding sash' construction or use experience on this site that could tell me whether this is a general problem with sliding sash that needs to be avoided by careful use, or whether it is indeed a design fault with these windows perhaps?
Thanks in advance for any advice about what is 'normal' for sliding sash.
