Option 1
Option 2
This is causing a bit of an argument between Mrs MdB and myself so we thought a few additional viewpoints would be useful. We are at the stage of fitting the slate floor and the pattern we use is up for debate. We can either run the same pattern throughout or we could change the pattern as it goes through each doorway using a strip of slate as threshold between the two areas. The utility room (bottom right hand room) already has the slate fitted into it so that is fixed but the rest can be changed.
Option 2
