Context:
Basement of a grade II listed building with brick walls, built on chalk. There is not much damp.
The floor is breathable limecrete ( I have just done that).
No DPC in the walls.
So there is moisture in the floor, walls and air.
I have had structural steel joists and posts put in. The first meter from the ground I have clad the steel with water resistant board- the kind you can use in bathrooms, and with green plasterboard in the upper parts. What would you render the boards with?
The brick walls, external and party, are mostly rendered with cement. That's how I found them. They are skimmed in part with pink gypsum. In parts they are skimmed with a grey/cement coloured skim. Parts were clad with plasterboard others with and old fashioned MDF- the light cardboardy version that you can break with your hands. Behind them there are raw bricks.
I would replace the MDF with green plasterboard.
So the walls are a bit of a crazy patchwork.
Would it be appropriate to skim everything with lime? On top of boards, cement etc?
A lime specialist who has proposed hacking all the cement and rendering with lime, but that would be a big job I'd prefer not to tackle, and also quite destructive, as it would take the front off all the bricks.
Any tips before I ask the Building Control inspector/CO?
I know that in the other listed buildings in the area they have used a high tech damp-resistant render.
