After removing my sash and replaceing rotten section I'm thinking about how best to put it back in the frame. It has a extended seperate cill, replaced with hardwood, which was orignally laying over the 2 leaves of a cavity wall with out any mortar. I'm wondering if I should put a strip of DPC and the mortar before putting it back. I've has to replace the bottom section of the frame and have used a piece of wood 1cm thinner so I can get some mortar in now.
the frame was fixed to the cill with nail knocked in from under the cill into the bottom of the frame. Is there a better method than this ie dowels T&G etc.
Many thanks.
Many thanks.
