I’ve never tried lime plastering before, I’ve always had it done by specialist tradesmen, however, I want to save some time and money by tackling a small task by myself and I would be grateful for some advice.
I’ve recently cut a channel in an old lime plastered wall for a light switch and associated cable and I want to backfill it. The channel is about 30mm deep by 30mm wide and runs from the switch up to the ceiling
I was planning on backfilling it with two coats of lime plaster, the first coat a mix of lime hydrate or lime putty with well graded sand in a proportion of 1 to 3 and then finally a finish coat.
Seeing this is quite a small but elongated hole, do I need any hair in the first coat? How deep should the first coat be and how long should I leave it before applying the finish coat? My last question is, what is the mix for the finish coat?
Many thanks
Many thanks
