lookseehear
- Somerset
Hello everyone - first post here and looking forwards to discussing houses with you all.
Our house was once two Somerset miner's cottages which were knocked through to create one house, then extended to the rear at some point in the 70s. The main part of the house is 400-500mm thick stone walls and the extension is concrete block faced with stone similar to the existing walls. Pointing is generally pretty poor, of mixed quality and with lime in places and cement in others. The roof is low-pitch with slate tiles, so no attic/very little loft storage. The felt doesn't look great and probably needs to be looked at in the not too distant future, and the extension roof structure was built on top of the existing one, which sounds like the lazy/cheap way to do it but I stand to be corrected here.
We have two young children (6 and 4) and we are planning fairly ambitious renovation works to turn this into a home we'll be happy to spend the next 15 years and probably some time beyond that. There are three main objectives:
We plan to put our living space on the first floor, which makes more sense than you might think because we're on a fairly steep hill so the garden slopes up to one end of the house, which also makes it much easier to open up the living space and has the benefit of enabling vaulted ceilings in the living space, while having lower ceilings in the cosier downstairs bedroom spaces.
From the reading that I've done and conversations we've had, I feel like my preferred approach is to externally insulate the stone walls and either replace the roof or to insulate between and above the rafters in the roof to create a 'tea cosy' over the house which combined with new (double or ideally triple glazed) windows and new modern doors should create a more air-tight and well insulated home. Our house isn't listed, nor are we in a conservation area and we're comfortable with the rendered look that this would create. I've considered IWI instead of EWI but I'd be concerned about several things:
- Improve the insulation and thermal characteristics of the building so that it's a comfortable building year-round and doesn't cost as much to heat. We aren't expecting passivhaus levels of thermal comfort here, but a significant improvement
- Create an open plan living space that suits the way we want to live and replace kitchens/bathrooms that are all very dated.
- Catch up on any needed maintenance that may have been neglected. We moved in three years ago but it was probate, so was only occupied intermittently in the period before we moved in. I'm thinking gutters, drainage, repairs to plaster etc.
- Cold bridging and risk of interstitial condensation
- I assume we'd still have to remove all cementitious mortar pointing externally because IWI would leave a colder wall with greater risk of spalling to the stone
- Reduction in room sizes to achieve a good level of insulation
