Keithj
- Witnesham, Suffolk
The extensive repair and extension work on our (Tudor) house was finished in early September, and we have the house back. (See copious earlier correspondence on here).
The builder and his foreman came to look at remaining snags last week. Most were straightforward - thin plaster skim separating from the nailheads that hold the plasterboard to the wall, for example. Those he will deal with.
All the sole plates, and about 10% of the studs, were replaced with green oak (it had to be green, apparently, because those are the rules). The new wood has now shrunk, and there are gaps through which one can see daylight (and feel the gentle breeze when it's blowing hard outside). There is no problem with the old timber and the new plaster/lime render.
"No problem", said the foreman, "I'll just fill those cracks with decorator's caulk".
My immediate reaction was "No, you won't", basically because decorator's caulk wasn't a normal Tudor material. I'm going to have to redecorate after this exercise anyway, and I'd prefer to do it neatly myself rather than have apprentice builder number three spread the stuff around the place. They used caulk to fill gaps in the original repairs at one side of the kitchen, and that's cracked and separated where the oak has shrunk, crazing the plaster in a way that a straight wood join wouldn't have done. I'll remove and fix that properly.
My instinct is to pack the cracks with wool (we have large quantities of "builder's wool" which was used to lag the walls), and then fill with lime putty outside, plaster inside. But before I go off and do the wrong thing ... what would be the team's view on the right way to fix these shrinkage cracks?
