jungle_jim01
- Loftus, North Yorkshire
More plaster/render chipping has revealed a window in my lean-to with no lintel. (1m span)
It's solid brick construction, 2 bricks thick. The outer leaf is supported by the window frame but the inner looks to be supported only by the mortar & render. As it's on the end wall of the lean-to there's very little above it. 2 courses of bricks at the low end and 5 at the high.
Question is, should i put concrete lintels in here before covering everything up again?
