nataliecampbell
We live in a grade 1 listed, 15th century, timber framed cottage. We have significant damp problems - which we believe to be caused by 'improvements' carried out in the 1970s, including the concreting of floors and application of cement renders to the walls. We have LBC to remove the concrete etc. However, under some of the floors we have discovered an original Victorian brick floor (presumably laid into earth) while in other places there is just earth. Our plan was to leave the brick floors as they are - however our contractor is strongly suggesting that we lift the floor, lay a breathable membrane, limecrete and then relay the floor - which I am not convinced about. With respect to the floors that are just earth I can see that there would be some benefit to doing this but surely if I then lay quarry tiles, for example, on top would this not create a barrier which would negate the efficacy of the limecrete (the quarry tiles would be in a kitchen so would have to be sealed)? Any advice would be gratefully received as we have had a number of conflicting suggestions.....
