briany
- Waterford, Ireland
For anyone with an engineering bent, I'm wondering about the rear wall of a victorian terraced house that I'm thinking of buying. There is a definite (not huge, but noticable) bulge at the rear wall, and I'm wondering how serious it is. The photo attached shows the location of the bulge, and the fact that there's a soil pipe in there suggests to me that there might be a long term leak into the wall fabric which has resulted in this bulge.
Might it also be just a symptom of age in the house? The whole house has definitely subsided to one side over the years (the slope in the floors and ceilings are testament to that), and this might be a contributing factor.
The other factor that I'm thinking about is that there isn't anything tying that wall at the centre to the rest of the house - the flooring joists run parallel to the front and rear walls, and all of the internal walls are lath and plaster. Might the wall simply be sagging under its own, unsupported, weight?
Really, what I'd be ever so grateful for is some advice on how serious this is. As I said, the bulge is noticable, but not dramatically so, and some settling over the years is to be expected and such idiosyncracies of individual houses are to be celebrated, so long as they aren't symptoms of imminent (i.e. sometime in the next twenty years) collapse. Would it be possible/advisable to put in one or more metal ties between front and rear walls, under the floors?
I realise that the advice of a good engineer here is essential, but engineers with skills in period property in Ireland are not easy to find, and I fully expect the stock advice to involve masses of concrete or demolition or both. Hence, I humbly solicit all of your valued and valuable opinions to arm myself with before bringing an engineer in.
Thanks ever so much,
Brian
Brian
