Hi All,
I know there have been questions about paint sprayers etc. in the past.
Not sure I mentioned this before but I have a Wagner Handiroll 550 semi-powered roller which is the sort where you suck the paint into the handle.
The quick answer is that I really rate it
No dipping the kettle every roll and it means you can keep rolling, just the odd squeeze to add fresh paint to the roller.
It seems to work works fine and be happy with clay paints.
It can really cover the ground on big paint jobs, you need to mask / cut lines before hand and be aware it can spatter if you get too keen, but worth the effort.
The down side is cleaning takes a while (so it is only worth it for big jobs), the handle is quite long when full which can be both awkward and useful.
A little video short from my channel. (Not been going long, and trying to grow the channel.)
Cheers,
Richard B.
Cheers,
Richard B.
