I am currently in the process of having my roof re-slated. Where the slates overlap the gable end there is a small gap between the underside of the slates and the top of the facia board. This is caused to some extent by the uneven top surface of an original timber moulding detail which is fixed to the top end of the facia board and has been weathered away over the years. I wish to keep the moulding as this is generally quite sound. I do however need to plug the gap. I was thinking of using the old lime torching method. Would you agree?
If so, what type of lime should I be using (hydrated or hydraulic) what type of sand and what proportion of mix. If I push this lime mix into the gap, should I first stuff it with newspaper to give the lime something to bond to and prevent it from pushing straight through into the roof space? I live on the south coast and this gable end can be subject to strong winds and driving rain so the seal has to be pretty sound. The roofer (a modern tradesman) had proposed using a modern waterproof roofing sealant but I think if I can get a lime seal in there it will probably last a lot longer.
