BigLebowski
hi there
I need to screw down new thick oak joists onto a load-bearing late medieval beam to stop it creeping.
The beam is at head-height and supports an external elevation, ie the side of the house.
I am stuck between using stainless steel coach screws or coach bolts. I am worried screws might
split or crack the old timber which is hard and brittle. Using coach bolts will be a bit more fiddly requiring
steel plates to accept the square slot head. I'm also unsure re. bolt sizes, eg M10 or M12 and if I
use screws, should they be recessed into the new oak or all the way through?
Are bolts or screws generally used in these circumstances?
Best
Dude
Best
Dude
