fernicarry
- Argyllshire
So, three years after the new kitchen was fitted I'm finally getting around to finishing the decorating. This is the first time ever I've painted sash windows and the first time I've looked closely at ours. The two in the kitchen are in generally good nick and have been draft proofed but I'm not very impressed with some of the details.
The parting beads are a really horrible looking plastic two part thing. One part fits into the rebate -- but not that well evidently as it is screwed and caulked in -- and the second part which carries the brush strip fits into the first. The join between the two is very, very noticeable and it all looks very plasticky. They might blend in a bit more if I paint them but I'd prefer to replace them with the wooden ones with the brush already routed in. Currently the brush strip is in two parts, the top has a single brush facing out and the bottom part has brushes pointing both ways. Can I get ready made wooden ones like this? I could probably just about manage routing out a slot for an extra strip at the bottom if not. Or is it more common to fit the wooden bead in two parts and just reverse the brush side to suit the top and bottom sashes?
Also cheap and nasty are the pulleys, on one of the two at least which seems to have a recently replaced case, the other pulleys are painted over, grrr, I hate painted over fittings. They are ordinary steel with plain bearings but the faceplaces are 110mm long (4 3/8"?) as opposed to the apparently much more common 4 5/8". Wheels are 1 3/4". Would like to swap them for something a bit more classy with ball bearings but don't particularly want to cut out a new rebate if can be avoided. Google has only found rectangular ones in that size but need radiussed. Anyone know of a source for this size?
This window also doesn't have enough weight to hold the bottom sash up properly which I initially ignored but now I think I need to pop off my nicely primed staff bead to get at the pocket. Is it normal to caulk between the staff bead and the box? All of these have been so it'll make a right mess taking them off. Scottish profile if it makes any difference.
And the final oddity is the lifts, a pic would be worth a thousands words here. They are the ring type but the flat plates that fit against the bottom rail aren't particularly square (0.5 - 1mm difference in width at opposite ends), the screw holes aren't on the same level and no two of them seems to be the same size or shape! They seem to be in two parts with a noticeable join between the ring and the plate. They've been there a good while judging by the layers of paint and the very dark colour. Unfortunately whoever last fitted them did a horrible job with the fixing holes and failed to compensate for the squintness so they are way off the vertical. Need to fill and re-drill to get them straight, in which case I'm tempted to replace them which would be a real shame given their obvious age. I thought maybe it was a front-of-house, back-of-house thing but all the windows are the same except the big room which looks like its already been treated to new ones.
Sigh, I knew there was a reason to keep putting this off but now I'm committed...
-Alan
-Alan
