I'm hoping that, with all the wealth of experience on this forum, someone might be able to help me.
I live in a Victorian house (built c. 1890) approximately 25m from a busy 30mph road and would like to lessen the traffic noise coming into the house (predominantly through the windows). The house has 4 bay windows at the front, each with 3 sets of sashes (1 over 1). The middle window in each bay is operable (the bottom sash moves freely) however all the other sashes are painted shut. The sashes contain single pane 3mm glass (very few panes are still the original glass) and the windows seem to be in a reasonable condition (apart from a few rotten window sills).
I have read every article I can find on the subject of noise transmission through windows and I get the impression that:
i) The three most influential factors that contribute towards a window's acoustic performance are: Ensuring a good seal between window and frame; acoustic performance of the glass; separation distance of glass panes if double glazing/secondary glazing is used (preferably >50 mm).
ii) Somewhat counter-intuitively, single-glazed laminate is as effective if not better at noise reduction than double glazing (see Pilkington Optiphon Ctr data in http://assetmanager-ws.pilkington.com/fileserver.aspx?cmd=get_file&ref=8222&cd=cd)
Although I recognise that the best acoustic option is to secondary glaze (with a decent sized gap between the secondary glazing and the window), that comes at a cost to aesthetics, or at least I haven’t been able to find any unobtrusive construction that doesn’t detract from the windows. That leaves me considering whether I can get sufficient improvements from the windows by either:
i) Refurbishing, increasing the rebate of the existing sashes to accommodate 10mm acoustic laminate glass, and draft proofing the sash that is operable in each window. However, I’m concerned that there will still be a lot of noise coming through the gaps even with well-designed draft proofing (I wouldn’t want to spend a small fortune on glass that on paper reduces noise by 10dB only to find it is not the dominant source of noise).
ii) Replacing all the sashes with new ones that accommodate DGUs made up of something like 6 mm / (6 - 16 mm) / 10 mm laminated. This is expensive and, although has been recommended to me by companies such as Ventrolla, I question whether this is the right option due to the loss of the original sashes. I have been quoted £20k+ for this option. It also seems to offer no additional acoustic benefits to the refurbish option (although there are thermal benefits).
Does anyone have real world experience of trying to improve the acoustic performance of sash windows that could offer some advice? It’s difficult to know who to engage to help.
I’d also be interested in finding a reputable local joiner in the Surrey area (nr London) who could assist me as I’m not an able DIYer
