I've got a 200 year old cottage with sash windows x 4 at the front. The property has previously had secondary doubleglazing, but was a reposession and the secondary glass has all been removed.
I want to remove the secondary glazing frames and replace the old wooden sash windows (partly rotten, most cords etc. broken, draughty and noisy). I'd like to put sash replacements back in, but avoid wooden ones if I can so I don't need to maintain them. I've been told that there are some very impressive UPVC ones now. I don't want the secondary frames as they're not very nice to look at.
I can get away with UPVC sash provided it's a good likeness to the original wooden units which are in there at the moment - here are some of the things I'd need:
- The sash bars would need to be internal and not stuck onto the glass
- I'd need the little sash frame 'feet' that sit at the bottom of the top sash
- I'd need white piping, not the black rubber stuff
Can anyone advise on a good supplier and fitter? I don't mind going to a big well-known upvc provider if someone can recommend one particular one for the quality of the product and fitting? I'm in west sussex if that helps.
Any recommendations very gratefully recieved!
