Geoff Flegg
I'm looking to draught proof my sashes, using one of the proprietary brush seal systems, whereby you replace the staff and parting beads with ones with brush pile carriers built in + rout a groove in the meeting rail to take the same.
http://www.reddiseals.com looks to be the most cost-effective supplier I can find, as unlike most of the rest they supply components individually rather than just as complete overhaul kits - i.e. you can order what you really need, not what a standard kit provides. If anyone knows any better please speak up!
The daft question is to do with the brush pile weatherstripping that goes in the carrier. Take for instance the staff bead, obviously it's only on the bottom half of the window that the weather stripping is actually required, i.e. to seal when the window is closed. But if you don't put the brush pile all the way up, do you get problems with it moving or getting dragged out of the carrier as the sash opens and closes? Same thing applies to the parting bead, but this time it's only the top half on the window that really needs the brush pile, but do you have to run it all the way down?
I hope that's clear!
