Can you sand lime plaster - for example if a corner where lime plaster has been applied is sharp and crisp can you sand it to make it softer and more rounded? TIA
Depends on how it carbonated - and how fully, sometimes you seem to have a hard surface 'shell' and it's much more crumbly underneath. Also depends on the hair/fibre content, you could end up with a lot of stray strands sticking out.
thanks - I think it will be a while before gently sanding corners is gong to come into play - the list of things to do just seems to steadily grow. :shock: But given the chance I may experiment in an out of the way place.
