I’ve just been up in one of my lofts. This particular loft is under a single elevation sloped roof on a single storey building which abuts a 9” thick brick wall. On the other side of the wall is the street and pavement. The upper part of the slope on this single elevation roof is therefore fixed to the brick wall and has a continual length of lapped lead flashing sealing the join between the brick and the slates all of which are in relatively good condition.The wall elevates a further 3 ft above the lead flashing.
Unfortunately, I have discovered that a timber plate which sits in this wall within the loft space and supports the ceiling joists of the building is rotten in several places, more rotten than good in fact. To add to this I discovered that the plate and sections of the lath plaster ceiling close to the wall were buried in a pile of slightly damp orange coloured sand almost like a plastering sand. So far I have removed a sack full of the sand and I’m only two thirds along the length of the loft.
I am assuming that this sand has come away from the pointing on the brick wall within the loft but on inspection the wall looks fairly good, no spalled bricks, no missing pointing, however the pointing is not of the decorative kind and it is the same colour as the piles of sand I have found (orange).
On the street side of the wall, all looks fine, good condition bricks and a harder whiter looking lime mortar pointing.
The wall could be anything up to 190 years old. The capping bricks have an almost rounded top and all look fine. The only problem with the wall is that it has a serious banana shaped bow from one end to the other when viewed from the street and in plan however I understand it has been like this for many years. I recently had it inspected by a structural engineer. He only viewed it from the street and from high level using a ladder and he assured me that it is quite sound.
Considering that there appears to be no pointing missing from the brickwork joints in the loft, dose anyone know what this sand could be and dose anything sound amiss here apart from the rotten plate?
