Nigel Watts
- London N7
I have a bespoke steel and glass bay window on the modern extension. It was made by a metalworker to a non-standard design and is now suffering from a rust problem.
The double glazed window units are held in an L-section steel frame with mastic. These L-section frames are only attached to the structural steelwork in a few places and a gap about 3/8 to 1/2 inches wide was left between the L-section frame and the structural steelwork. The gap in the steelwork was then filled with mastic. Water has now penetrated between the mastic and the steel causing, in some place, very bad rusting.
The first pic shows the symptoms before I removed the mastic (the top join has failed but the lower one is still in reasonable nick):
The next pic shows what it looks like after mastic removal:
How should I repair this? I could try to remove all the rust (difficult given the narrowness and depth of the gap), repaint and then remastic. A more radical, and probably better solution might be to get a welder in to weld the gap. This would almost certainly crack the glass however, although some of it needs replacing anyway.
Ideas would be appreciated.
