Geoff Flegg
Ahh, the wonders of Victorian craftmanship....
Whilst getting the leaded light window at the bottom of our stairs repaired, I thougth I'd also take the opportunity to attend to any repairs to the frame, and re-decorate it with linseed paint. Externally, the area surrounding the frame had a hefty border of cement mortar, which was breaking away - which on cutting out has revealed a large gap between the brickwork and the frame, about 3/4" wide and several inches deep.
It looks like the stone lintel above was cut too deep, and the builder just shoved the frame in any way, hence the gap with the brickwork! Not the first bodge I've found, and doubtless won't be the last.
Question is what is best to fill the gap? I know people recommend burnt sand mastic, but that presumably is for small gaps round frames. My initial thought is to whack it full of lime mortar, then add a fillet of burnt sand mastic between the mortar and the frame at a later date.
The cement mortar that was in there had long since parted company with the brickwork, but was stuck soldly to the wooden frame, which seems the wrong way round!
Geoff
Geoff
