jungle_jim01
- Loftus, North Yorkshire
Hi, I'm currently in the process of raking out/repointing my Sandstone House. (thanks to everyone's advice last time i posted...getting to grips with the lime mortar!)
I've started on a lean-to extension which must have been built in the early 1900s i reckon. The lean-to is brick (which i'm not repointing)...but one end is formed by a much older Sandstone wall. It looks like this may have originally been a garden wall which they've used to form one end of the lean-to. From the outside this wall doesn't look too bad apart from bodged cement pointing ontop of the older lime stuff! As i'm pulling out the loose cement pointing, i'm finding some quite large voids and it appears to have a rubble infill. My question is...can i just pack in the lime mortar and build up slowly or should i be trying to pump some grout or something into the middle of the wall??
Thanks for any advice
