RedwoodRenovation
Hi,
First post to the forum, have been reading it for a while and have decided to take the plunge!
I've got some joist ends which are rotten at the external wall end, where they go into the 18 inch stone wall. I've removed the cement render from the outside and will be repointing and rendering in lime!
I'm thinking of removing six inches from the end of each joist and slipping in a new wall plate and then using joist hangers to re-hang the joists from that.
Question is, can you use a 6 inch wall plate and if so, what is the best method to bolt it to the wall?
Graham
Graham
