I have a 60 square meter flat roof which I want to use as a roof terrace with decking and large planters.
My concern is that the waterproofing capsheet layer and the insulation under it are soft and that any decking supports I put on it would press into them and eventually puncture the capsheet, resulting in a leeking roof.
I have asked the help of a roof garden specialist, ( http://www.mylandscapes.co.uk/ ) but although he seems to know about plants, planters and decking, he knows nothing about the roofs they go on. He would have just put the decking directly on the capsheet. In answer to my concerns, he has just told me to find a solution and call him when the site is ready to lay his decking.
A decking company ( http://www.citydecking.co.uk/roof.html ) advised me that it is sufficient to place rubber pads under the decking supports.
I have asked a structural engineer to look into a solution. He initially sugested laying an "egg carton type" draining board used in green roofs to spread the weight and ensure draining. He's getting back to me with a solution.
In Italy (where I grew up) and Spain, they have a lot of roof terraces. There they would cover the capsheet with plastic sheet or 3 cm thick polystirene, then ad a 10 cm light agregate screed with zink grid armour, and then tile.
The plastic sheet is for water protection, the polystirene protects the capsheet from splitting if the concreete cracks, the zink grid prevents the concrete from crackng too much. Probably efficient, but expensive and I'm not sure a brit builder would know how to prepare the screed.
My fear is that I have invested in a new roof, and then I lay decking and put a load of planters on it and after a year I have to strip the wole thing off to find a leak.
For reference, here is the exisdting roof specification built working with building control and the structural engineer, the roof has recently been reinforced with double joists.
on top of the joists are the following layers:
- 18mm WBP ply
- Marley Goldseal vapor control layer
- 150mm kingspan TR21 insulation
- Marley Gold venting underlay
- Marley Goldseal underlay
- Marley Gold capsheet
Any thoughts?
- 18mm WBP ply
Any thoughts?
