Nigel Watts
- London N7
My 1988 English Heritage Handbook on Mortars, Plasters and Renders has just arrived.
My stucco seems likely to be Roman cement as it has "the distinctive pinky-brown colour". Posher London Houses, such as Nash's Regents Park terraces, seem to have been given a mastic finish which mine clearly wasn't, but a piece of detached moulding has a dark grey clinker-like quality, the composition of which which I have yet to identify.
The book states that as these Roman cements are no longer made the best material to use for repair is a cement, lime and sand mix and that the colour can be approximated through a careful choice of sand. The use of cement in the mix rather surprises me. I wonder if this is still considered best practice? I guess lime alone would be too weak.
Interestingly the author states that "much Roman cement stucco was coloured with with a fine wash of lime putty, tallow and copperas (iron sulphate which is brown-red in colour) to simulate Bath stone colour. This coating was usually applied while the Roman cement was damp and therefore stained the outer portion of the render."
It recommends that hollow sounding bits should be cut out and re-rendered and recommends, where the render has been scored to simulate ashlar blocks, that the old render in the defective areas is cut back to these simulated joint lines to give a neater finish, even if that means cutting out areas of sound original work - a good tip I think.
