A
Anonymous
Guest
Hi all
I have a suspected rising damp problem on the interior face of a perimeter wall, on a listed 17th C property. The wall is plastered internally with hydrated lime plaster and is showing dark patches near the junction with the interior floor. The interior floor is new and solid with a membrane. There are also damp patches which appear to be a result of water penetrating through the solid 9 inch wall. The property has no guttering.
The mineral breathable paints I have looked at require a maximum surface wetness of 18% and the damp patches are wetter than that. I am therefore unable presently to paint.
The advice I have received so far is to paint the wall with porous "cellar paint". This only comes in white and I suspect it would still show the darker damp patches from behind. White would also not fit in with the proposed colour scheme of the room.
Other advice I have read is to fit guttering and improve drainage around the base of the walls externally by making a run-off chamber (more efficient than a French Drain which can block). Also I can excavate a few inches around the base of the interior wall inside the property and ventilate it within the room but this will disrupt the solid interior floor and could potentially look awful with floor grilles. Is it possible that these measures will reduce the surface wetness to less than 18% so it can be painted?
Another possible option is the insertion of a slate or chemical DPC. Is this generally allowed by local councils on old listed buildings?
Rob
Rob
