monmaison2009
Hi,
I am putting back the original ceiling rose in my property (it was removed by the previous owner), when removing the new plaster I have found some electrical cables ( I could not believe my luck !) so I arranged for the electrician to come and check everything was ok ....
In short it is not, apparently the electrical cable leaks electricity so even when the wall switch is off there is still 50 Kw running through, apparently this is a no no (risk of electric shock)
The bad news is that to put a new cable part of the original lime plaster in the ceiling has to be removed and a groove made in the ceiling beams to run the cable .... :?
I was wondering if any of you had to do something similar and if there is any alternatives with minimal impact
Thank you very much for your help and advise
