sevenleaf
- Bedfordshire
Following from the excellent advice from Helen Foster, plasticpigeon, 88v8 (Ivor) and FlyFisher regarding laying our floor tiles, I was hoping to again draw on the collective knowledge of the forum for approval and ideas of how to proceed with finishing and weatherproofing the outside of our timber framed cottage that had seen better days when we purchased it.
We have nearly finished removing the plastic paint that was covering the limewash - which had all failed in places, blown/spalled some bricks and had left the wall in a very patchy and messy state. Some parts of the wall were rebuilt completely when we had the place underpinned, failed bricks were replaced and failed joints were re-pointed.
Now we are looking for advice with how best to:
1. Protect and enhance the exposed (and vunerable) oak timbers. These look to have been covered with a very hard substance in the past (probably the rock-hard cement used in abundance elsewhere), which has mainly failed and fallen off. This will pick off without causing any damage to the oak underneath. I'd like to retain/renew the black appearance and protect the oak (which is as soft as cork in some places) from the elements. Should I scrape this back to good - pictutre 2?
2. Create a 'lip' to prevent water from water working its way under the oak timbers. You can see where a previous attempt has failed and come away. I have had two suggestions - a lead trim (not keen, concerned of water ingress behind/underneath) and a new shallow lip up to the wood, similar to before however with a lime-based mix this time - limewashed over.
3. Finishing the surface of the wall. All of the white is limewash and we are very keen to continue this. Most of the loose has been raked back to good already, the rest will be done prior to any further work. Some repointing has been carried out although not to an amazing standard. One concern is how well further limewashing will fit in with the existing, however we would prefer any patchiness to the alternative of removing all existing back to brick and starting from scratch - as showing the progressoin of the property is part of its charm to us.
