plasticpigeon
- Birmingham
Happy New to everyone. I wish a warm and dust and damp free 2015 to you all.
This Christmas break I intended to install a fireplace in my front room, which involves quite a lot of work, including pouring a constructional hearth and building brick jambs within a builders opening, and tiling the new hearth. I also wanted to patch up the lime plaster on the walls that were covered with woodchip on the ceiling and above the picture rail and some other gloss painted textured paper below. After taking off the wallpaper, I think about 70% of the plaster remains, and it is pretty shabby, and the lime render below the setting coat is so weak in lime it is red and sandy and crubles to dust in the fingers. Also the skirting boards in one alcove and by the bay window were pretty rotten to the point that they turned to dust when I removed them to try and level the floor. I used to mock scorn on people that just ripped everything out wholesale and started again with new woodwork and plasterboard. However I have spent nearly a week of fruitless work preparing to make the walls good, and from now on i think in the other rooms where the plaster is obviously even worse i will just get folks in to rip it all out and start again. I will reinstate woodwork that isn't rotten and get stuff matched, so i don't think people will know it isn't original. I know this isn't proper restoration, but I'm beginning to think it the only solution, if a house is going to be a home and not a lifetimes project.
