jungle_jim01
- Loftus, North Yorkshire
Hello again. Firstly thanks to everyone's support and advice on my previous posts about lime pointing. I've had a bit of practice on the Garden wall which has worked well and am now moving onto the main house. The cement ribbon pointing in my sandstone house is just falling out which makes life a little easier. However, the window reveals are rendered in newer cement which seems fairly well bonded. Ideally i'd like to chip this out too and have sandstone reveals. I'm worried about damaging the stone and also unsure of how to seal the window frame once i remove the render? Presumably if i can remove the cement, then i can use the hydraulic lime mortar to fillet around the edge of the frame? Any tips on treating/painting the frame before/after how to make a good bond/seal etc would be really appreciated...feeling slightly nervous about chipping out the cement render!
Chris
Chris
